I need if someone can help me to process stop & go files with RTKLIB and then how to export all the surveyed points to turn them into flat coordinates. I do not know what the results are. I still do not have the EMLID GPS coming. Thank you
Luis
Do you have the start/stop timings from a survey or just noted down?
Hi Luis
If you are looking at post-processing stop & go sites recorded with Emlid ReachView application, EZSurv post-processing software can read the points collected by ReachView and thus it will output the post-processed results for your surveyed points.
EZSurv can also post-process UAV flight data and interpolate photo positions captured by Emlid product. The file output is the ready to be used in your image processing software.
See below 2 YouTube videos that explain the workflow:
