Hello, I am doing RTK with two RS2 and I only have correction until 150 or 200 meters. There are only a few trees that take away direct vision, but I think the distance should be greater (There are no medium or high voltage lines). I would like to know if something like this happened to them and how far do you work in RTK. I use the settings suggested by the tutorials.
Best regards
So Beyond that distance you are not receiving corrections, it that how I should understand it?
Exactly. Only up to 200 meters away do I have a radio signal. I would like to know if it could be an error in the configuration or equipment failure.
Can you provide a screenshot of your base mode tab from Reachview?
Your data-rate might be too low for the interval and amount of messages your are trying to sent. Can you try the highest data-rate, or the opposite, only GPS MSM4+ARP.
Thank you.
Tomorrow I will test that configuration
