I look into the help: https://docs.emlid.com/reach/firmware-reflashing/
So I downloaded and installed the intel utility. This util wants 2 (!!!) usb cables to the Intel Edison but there is only one usb connector on the reach module…
What I am doing wrong?
I then tried to use the terminal mode of flashing the reach module:
installed intel Edision driver and start CMD.exe. Run flashall.bat and got an error that DFU-util is not found!!
after some time i got an error message: Dfu device not found Timeout Did you plug and reboot your board? If yes, please try a recovery by calling this script with the --recovery option
Hi Franz,
I had similar problems and I have posted elsewhere in this forum about my experience.
In summary:
I only used the Intel GUI to install the drivers after that it is better to use the flashall script (flashall.bat/flashall.sh) from a command line. It shows much better progress reports and will indicate if anything failed more clearly.
Try different USB cables. I though I had good cables, I had used them many times for flashing other devices, but it consistently failed so I started using a short cable supplied with another product and it worked.
The USB port may also be a factor. Try different ports or even a different computer.
