I am having difficulty in accessing ReachView Applications on Windows 7 and Windows 10. And, I am not using any virtual PC. Sorry for long post.
I will explain, what I did, step-by-step for Windows 7 and Windows 10. Windows 7 Step1 – Reflash reach by using flashall.bat Step 2 – Go to “Control Panel\Network and Internet\Network Connections” and select Ethernet (Unidentified Network) (Intel Edison USB RNDIS Device) – Properties and changed IPv4 connectivity as:
IP address: 192.168.2.2
Mask: 255.255.255.0
Default Gateway: 192.168.1.1
Apply changes and done!! Step 3 – Now go to http://reach.local and I can access the ReachView Applications.
I even can access ReachView application on 192.168.2.15 Problem: When I go to Config page, the application always loading for “infinity” time.
I even clear cookies, cached, everything. I changed brower to Safari (Windows), Firefox and did everything but no results. ReachView Application always loading only in Config tab.
I am stuck in “Config tab” on Windows 7. Rest everything works.
Therefore I switched to Windows 10. Windows 10: Step 1 – Reflash reach by using flashall.bat Step 2 – Go to “Control Panel\Network and Internet\Network Connections” and select Ethernet (Unidentified Network) – (Intel Edison USB RNDIS Device) Properties and changed IPv4 connectivity as:
Mask: 255.255.255.0
When I apply changes, it comes this:
Step 3 - I did “yes” Step 4 – When I go to http://reach.local then I cannot access the ReachView Applications. But I can access ReachView application on 192.168.2.15. Problem: The main problem is if I setup Wi-fi through 192.168.2.15 then I cannot use RTKPLOT.
So please help me.
I need some solution for either Windows 7 or Windows 10 or both:
(a) Windows 7 which indefinitely loading on Config page, or
(b) for Widows 10 so that I can access application at http://reach.local as well as 192.168.2.15 (which is doing currently for this IP).
“reach.local” method relies on bonjour discovery, so you need to have bonjour installed. It comes as a component of many popular programs such as Itunes, Skype and some other so many have it installed even without knowing it. You can install it separately as well.
Thanks @igor.vereninov
In my Windows 10, Bonjour was not installed. I can access “reach.local”. But the problem is now same like Windows 7. The config tab keeps on loading for indefinite time. I cleared my cache and cookies but no result. I restarted my computer too. And yes I updated to latest version.
Oh ok. Thanks. Now I have to work on getting single to fix. Because its always single even if I have 6-7 green bars satellite. I have put both receivers on the two car (top).
