I have an RS2 and a M+ module, and since I’ve had some issues with Ntrip I wanted to give a try on the Posprocessor v0.3.0 point extractor developed by user jurijs.jeshkins to test PPK
-Base: Reach M+ module
-Rover: RS2
-5 points were recorded in 3 different sessions:
Session 1: GPS+GLO+GAL constellations
Session 2: GPS+GLO
Session 3: GPS
Each session consisted in turning on RS2, record a point for 10 minutes and then record each of the five points for 5seg, 10seg, and 15seg and then turning off the RS2.
So there are a total of 9 records for each point combining different constellations and record times.
Ground Track for one of the sessions. Then used Point Extractor to get the final coordinates for the points.
All solutions were Fixed with differences of about 2/3cm in XY and similar for Z.
The different point colours represent the 3 different sessions (GPS+GLO+GAL, GPS+GLO and GPS only)
Point 1
Point 2
Point 3
Point 4
Point 5
Post processing was using L1 only. So it would be equivalent to be using 2 Reach RS+.
So I can say that using M+ as base ans RS2 as rover I can get very good results doing PPK, recording a point for only 5 seconds. At least at short distances. On this test the max distance between base and rover was 200m. I will test distances of 3 or 4km that would be more realistic for a real job.
