Dear Friend
hi everyone, I have a problem when I tried to correct data on TBC, When I use the RS+ there are no problems and the presición in point around a hour is around 0.009m.
But when i take a point with RS2 with the same configuration TBC give the problem “Solution type= Failed”.
Both devices are in 1hz of ratio and the same version of rinex (i tried with 2.11 and 3.02 rinex.)
I looking for some recomendation or know about your expirence.
Most likely, you need to make the intervals in the RINEX integer. At the moment, there is no such feature in Emlid Studio, but you can still do that in RTKConv. Please check this my post:
Dear friends
I just find a solution, the problem was around TBC 5.2 version, I just uninstall and reinstall the v5.0 version and then could correct the data.
