michaelL
(Michael Lambert)
February 17, 2020, 1:02am
1
Some links I pulled from the web that were helpful. Hopefully the culmination will help others as well. I’ll add more if I come across any good stuff. You all please do the same!
Ya Peeps
Reachview PPK Setup
The purpose here is to show you the basic ReachView settings for PPK.
I have provided screenshots of each tab within ReachView and annotated them in RED writing.
We will not discuss post-processing here, only ReachView settings.
NOTE*
The settings below are exactly the same for base and rover. That is because the choice between base and rover is something that is done afterward when you post-process your log files.
At the bottom of each picture, I have rewritten the English text for people wh…
PPK Droning (P4RTK)
Flight - Discussion and Q&A
Here are the instructions for using RTKLib to process the P4RTK flight data. Aerotas has done a excellent write-up on how to process the data and I’ve added a few images to help clarify the steps. Follow the steps in the link above and use the...
Reading time: 9 mins 🕑
Likes: 34 ❤
RTKLIB Video
RTKLIB Walkthrough
https://bad-elf.com/pages/post-processing-gnss-data-with-rtklib-introduction
Michael,
Thanks for sharing helpful tips!
Hopefully, more users would do the same and post-processing will get a bit easier
system
(system)
Closed
May 27, 2020, 7:18am
3
