in PPK mode with more than 3km baseline how many minutes should you obseved the point with open skyview. is 5 minutes is enough?
More than 3 km, is that then 3.5 or 10 km or?
I would go for 25min rapid static.
I think 20 min is enough for multi frequency receiver but more time is better.
For a single frequency receiver 30 min is good.
Here is one recommendation from the IBGE (Brazilian Institute of Geography and Statistics) provided by mauricioranzan (Mauricio Surveyor) in another post.
last time i did ppk i notice that when the baseline is less than 1km 1-2min can solve fix, less than 2km 5min fix but more than 3km i observed it 5min solution is float.
There is a saying you may find in the scientific literature about the recording time in static mode. It is :
time = 10 minutes + 1 minute per kilometer of baseline + 1 minute per 100 meter of height difference
Hi @willstar_beleno,
5-10 minutes should be enough in good environmental conditions at a 3 km baseline. If you can achieve only a Float solution, please share the logs from the rover and base with me. I’ll check the data quality and try to post-process the data to see what can be wrong.
