PPK field data collected with qfield
Hello all!
I recently collected field data using qfield and I want to apply corrections to the point data using EMLID Studio. However, Emlid Studio will not accept the .csv created from QGIS. I was hoping someone might be able to provide some insight on this matter.
Eemlid_CSV - copia.zip (3.1 KB)
Many thanks!
Andrew
mobiliariotest.zip (4.5 KB)
I have also uploaded the original shapefile as it may also be of interest in resolving this issue.
Cheers!
Hey Andrew!
If I understand correctly, you are using Emlid Studio’s Stop&Go feature. This feature is designed to work seamlessly with Reach receivers and the Emlid Flow app. The issue you’re facing is likely due to the CSV format from QGIS not matching what Emlid Studio expects.
Unfortunately, there’s no direct way to get the exact required format from other receivers. The workaround is manually editing the CSV file to include the necessary fields. Specifically, you’ll need to add columns for Averaging start and Averaging ends, formatted as YYYY-MM-DD HH:MM:SS.0 UTC-0X:00. Example: 2024-10-20 14:15:24.0 UTC+04:00.
Some users have successfully used AI tools to help with CSV formatting, so that might be worth exploring as well.
Hope this helps! Let me know if you have any questions.
