I collected data with a base and a rover using LoRA setup. However, I did not have corrections for my base in the field. I am trying to PPK the base data using CORS data and then correct the rover data that is fixed to the base.
The workflow in Emlid studio is:
Static processing of the base
Receiver: Raw rinex from base, and added in the height of my pole
Base: CORS obs file
Navigation: Base .P file
Stop and go processing of the rover
Receiver: raw rinex from rover
Navigation: Rover .P file Base: the PPK base data. However the output from static processing is only a .POS file that is not usable here. How do I PPK my base to where I can get data to correct the rover?
I went ahead and added the raw obs file for my base during the stop and go processing of the rover points. I then switched from header to lat/long/height dd and manually entered the position and height I got from statically processing my base file.
The question I still have is, do I have to put the measured height in both steps for my base? In the static processing of the base, I added in the measured height of my pole, and I did it again when I used this base to PPK the rover data.
The workflow that you described is correct. You need to use the same observation file from your base with both processes. In the case of Stop & Go, you can also drag and drop the POS file from Static processing.
