OTG to land adapter Query - M2 + UE200
Hi I’m using the exact setup as discussed here to connect an M2 to LAN using tp-link UE200 lan adapter: (M2 FW 26.5)
https://community.emlid.com/t/usb-to-ethernet-adapter-works-with-reach-m-but-not-with-m2/19906
Unfortunately the adapter will not work at mo. Do you know if it is still supported.
Thanks,
Con.
Hi Conor,
Some of our users successfully integrated Reach M2 with the TP-LINK UE200 adapter. We haven’t changed anything since then.
As such an integration isn’t worked for you now, please generate a Full System Report on your device. Full System Reports may contain sensitive information, so I’d recommend sharing them via support@emlid.com. It’ll allow us to investigate your case.
Thanks for getting back. I’ll send the files. Going to test on a second M2 for interest.
Conor.
Hi there,
Just want to note that we’ve received data from Conor.
I’ll post an update in this thread as soon as we get any results.
