You should measure to the base of the unit base, +134 mm. OPUS doesn’t read the rinex header antenna info. You have to enter the actual height in meters as shown below. Something’s not entered right. Maybe you selected an invalid antenna ? You should select “none”. The distance entered would compute to the ground mark
