Hi! I have a Hex Hereflow and was wondering if it is compatible with Navio2?
I am planning to connect it to the I2C port but am not sure if it works and the configuration required to ensure it works to allow the drone to have a position estimate. I would greatly appreciate any help in regards to the setting up process.
The HereFlow optical flow sensor is a lightweight optical flow sensor including a short range lidar which uses the CAN protocol to communicate with the autopilot.
Yes, i am aware. I was just thinking if it can work with I2C.
Do you know some optical flows that are compatible with Navio2 & the setting up process required?
We haven’t tested Navio2 with any specific flow sensors, so I can’t comment on it. But maybe Marc can share his experience. I’ve found mention of the Matek 3901 LOX sensor testing on the UART port in this thread.
I can confirm that there’s no CAN port and there’s an I2C port on Navio2.
We haven’t tested the Hex Hereflow sensor, so I can’t specify if this sensor supports the I2C connection. There’s only mention of a CAN port on the website Marc provided tho.
