Hi All,
Is there something I need to change in order to get my Matek 3901 LOX sensor to work with Navio 2 on the UART port?
I am assuming I will need to change this in /etc/default/arducopter
I adjusted the arducopter settings on Mission Planner to the suggested ones listed here:
http://www.mateksys.com/?portfolio=3901-l0x#tab-id-3
mlebret
(Marc Lebret)
2
Hello,
I will try to help. I used a Benewake TF-Mini with a Navio2.
/etc/default/arducopter settings:
Telem1 is wifi UDP to my computer,
Telem2 is Sik radio on USB
Telem3 is Range finder on UART “-F /dev/ttyAMA0”
Serial settings:
-F is serial 5…
Set protocol according to your need (32?)
Benewake Range finder settings:
Thank you for helping me out with this!
I went through and adjusted the arducopter file to match what you have exactly
32 looks to be the correct protocal for the Matek sensor (MSP). I changed them on Serial 5 (and others just in case)
I am going to download the latest version of arducopter and see what happens. I have version 4.0.3 at the moment.
system
(system)
Closed
6
