I can connect and stream ok from my pc using the BNC app as described here.
But when I try the same settings on my emlid Reach RS+ under “Correction Input”/“NTRIP”, I see the mount points ok and choose mine, but I keep getting “Recv error (114)”.
I am thinking that it isn’t working because of the SSL certificate requirement which I can setup on my pc ok, but my emlid has no place to enter it.
I can connect to other casters and mountpoints without any problems.
I know I can always post-process, but I am using this in the Galapagos Islands (CDDIS has a station there) and it would be so nice to have real-time fixes there.
My credentials also give access to 2 other stations and all work with the BNC app … try “GLPS0”, “GODE0”, “BOGT0” if you want to try others.
What in that string indicates that it is not up? You cited … “STR;GLPS0;Puerto Ayora;RTCM 3;1076(1);2;GPS;JPL;ECU;-0.74;-90.30;0;0;JAVAD TRE_G3TH DELTA;none;B;N;4500;”
I am thinking it is something with the SSL certificate and port 443 requirement with emlid … my other NTRIPs work ok with my emlid.
Any advice? I greatly appreciate your time. Thanks
Unfortunately, I think you’re right. This issue is related to SSL certificate. So, at the moment it’s impossible to connect Reach to that kind of NTRIP casters.
Maybe you can try to get corrections on your PC and send it to Reach but this scheme needs to be tested.
