Hallo, I have an Issue: since I updated the firmware (also flashed it and redid set up), the RS2 does not receive corrections (no FIX status). I tried everything. Please help!
Thank you.
Thank you.
Which version of firmware? We just upgraded to v29 and everything seems to be working ok.
After a flash, the unit can lose some settings. How the receiver usually receive corrections ? NTRIP or LoRa (or others) ? Maybe check the corrections input parameters.
Do you use a SIM card in it, and if yes, have you checked the Mobile data settings ?
Hello, thanks for the instant support. I tried some more, it seems to work again.
