I don’t have much information at this point. I took my new Navio+ out to the field to fly, and I couldn’t get a lock. Everything else seems fine, just no GPS. I followed the docs on auto-starting the software, but no luck.
What is the gps status in the GCS? Is it “1” or “0” ?
It might take up to 10 min to get a lock in a new location, another reason might be interference with some equipment on board.
The best way to debug and improve GPS positioning is by connecting to u-center software as shown in the docs and observing SNR levels. You should have 4-5 sats with SNR around 45+.
This is most likely some kind of interference issue, try moving antenna as far from everything as possible and also leave only necessary equipment for the test connected.
We just had a case with a damaged antenna cable where it connects to the antenna, so this is also an option.
Ok, I spend some time looking into what’s going on. I can now get a lock occasionally. I believe that there is an issue with the cable at the connector. Wiggling that connection, while keeping the connector to the to board stationary, results in a loss of GPS signal. Can you provide the specifications on the antenna so I can buy a spare?
Sorry for taking so long to get to this. I’m now doubt that this was an antenna issue. I’ve now three separate antennas, and all respond the same.
I sent the aircraft out for a flight (manual only), and have attached the plot of the number of visible satellites. It fluctuates wildly.
I then SSHed into the plane on the ground and monitored the GPS using u-Center. I saw the same fluctuations in the GPS sats. This is the same across the two antennas I tested. Photos are attached.
@capucsc could you please make the following test: Under open sky turn Navio+ on and connect to u-center. Observe SNR levels, you should see 4-5 satellites around 40 dBHz. If not, try to move the antenna around, do not place it directly on the Pi. If nothing changes, your antenna might be faulty.
If in this test you will see same SNRs as on your screenshots, PM me and we will issue an antenna replacement.
Hi Igor, i m following this post cause i have exactly the same issue with the GPS, i have two antennas and two navio+ boards. I never had a GPS lock, tested with 2 antennas on each boards and with the VTX off.
For future reference and reporting GPS lock issues. To determine whether your GPS works or not, make a separated test. Take your Navio+ and RPI to an open area (field, park, backyard) where multiple satellites are visible. Connect antenna, connect to u-center software as shown in the docs and wait for 3-5 minutes (usually 40s would be enough).
Here is what your SNR levels should look like, or better:
It is very important that you place the antenna as far away from RPi as the cable allows and that you do not have any other equipment connected while performing tests (no 3G/4G modems, no cameras etc. )
@florent451 hmm… it would be a very unrealistic scenarios with two faulty boards at once. Are you sure there is no other equipment running that might create interference? Could you test it not on the copter as described above?
@ivereninov – I just ordered a second board. I’ll do a comparison later today (if the rain lets up) or tomorrow. Hopefully the new board solves the problem. Thanks for the example, I’ll know what to look for.
