If you followed these instructions - http://docs.emlid.com/Navio-dev/GPS-ucenter/ - then you’re connecting to the Navio’s onboard GPS, not the USB dongle. You can connect to the USB dongle by using socat to pass data from /dev/ttyACM0 to tcp port.
I’m not able to pass the data with socal. I’m new in these things and still have to leran a lot.
After a lot of trial and error I found the command:
socat TCP-LISTEN:5000,fork /dev/ttyACM0,raw &
But the answer is “Adress already in use”. Can you help me with the correct command?
My idea was to connect the Neo-usb-dongle to the Navio+ to get the raw data and thereby RTK-Perfomance. But is it necessary for that at all or can I connect the Tallysman Antenna directly to the Navio+?
Then the dongle would be available to build a reference-station!?
If I plug in the dongle directly to my PC I get a fix within a few seconds (see it in u-center)! But I want to use it plugged in the Navio for havin a RTK-system.
So thanks for the syntax, but the answer I get is the same: “Adress already in use”!?
the complete error-code is: 2015/10/04 19:10:20 socat[2390] E bind(4, {AF=2 0.0.0.0:5000}, 16): Address already in use
I followed the docs and tried to get a signal in the u-center. That’s just to clarify that everything works with the GPS dongle and antenna. But it seems not (on the Navio)
In general I want to build a rover that can navigate with RTK-precision over APM. For now I do not have any reference-station and therefore cannot have high precision. But I already want to build the rover to test with “normal” GPS-Performance until the REACH gets available and I can build a reference station.
My setup for now is:
RaspPi2 with Navio+ and the following hardware connected:
3DR telemtery connected over UART
Neo6T-USB dongle with Tallysman GPS Antenna connected
USB-Wlan adapter for Communication to base station
My “base-station” is a dektop-windows PC with APM and u-center installed. I have also conneceted the 3DR ground-modul to my PC to communicate to APM.
Later I want to build a reference station with a REACH to have RTK.
You say that
So I cannot use Navio’s onboard GPS for RTK, right!? Thus the Neo6T-USB-dongle!?
Perhaps I’m getting something abolutely wrong; hope you can help me
OK. It works now!
I made a mistake by opening the tcp port as described in the docsand after that tried to pass data with socat to the tcp port.
The solution was to only call the socat command.
But one question still isn’t answered:
I cannot use Navio’s onboard GPS for RTK, or is it possible? Then I wouldn’t need the dongle in the navio at all and could use it to build a reference station with it.
