Is it possible if you can inform me if the NMEA string of the Reach RS + contains all the information of the satellites observed?
Reach currently supports the following NMEA messages: GNRMC, GNGGA, GPGSA, GLGSA, GAGSA, GPGSV, GLGSV, GAGSV, GNGST, GNVTG.
Whick one do you need, @agrimgalina?
Andrew survece only read gps
@agrimgalina, usually software can choose needed messages from the data stream.
Also, we’ve SurvCE tutorial and a lot of users working with it. So, it should work fine.
To sum up this SurvCE issue, there’s an answer from Tatyana in this thread:
