Navio2 UART hardware control flow
Is it possible to enable hardware control flow in the Navio2 UART port? I noticed that in the pinout diagrams there are two pins in the UART port labeled IO17 and IO18. Can they be used as CTS and RTS pins?
Thanks
@Gabriel_Moreno it is not possible out of the box, but they can be controlled manually. Check this thread from Raspberry Pi forum:
https://www.raspberrypi.org/forums/viewtopic.php?t=12317
