vcompl
(Martin)
June 6, 2017, 12:05pm
1
I have NAVIO2
Using APM planner 2
I get Battery Voltage and and Current 0
When I run I get:
cat /sys/kernel/rcio/adc/ch0
cat /sys/kernel/rcio/adc/ch2
cat /sys/kernel/rcio/adc/ch3
Jun 06 11:45:33 navio systemd[1]: Started ArduPilot for Linux.
pi@navio:~ $ cat /sys/kernel/rcio/adc/ch0
5230
pi@navio:~ $ cat /sys/kernel/rcio/adc/ch2
1028
pi@navio:~ $ cat /sys/kernel/rcio/adc/ch3
58
is this read out from Raspi ok?
What is missing? Some setup in APM planner 2 ?
Please give some directions
Hello there!
Is this happening during a flight? The power module is only able to measure currents around 10 amps.
vcompl
(Martin)
June 7, 2017, 9:25pm
6
This is on the ground.
Below result from ADC python:
pi@navio:~/Navio2/Python $ sudo python ADC.py
A0: 5.2240V A1: 0.0280V A2: 1.0160V A3: 0.0400V A4: 0.0080V A5: 0.0300V
A0: 5.2460V A1: 0.0280V A2: 1.0240V A3: 0.0400V A4: 0.0320V A5: 0.0140V
A0: 5.2480V A1: 0.0240V A2: 1.0280V A3: 0.0480V A4: 0.0080V A5: 0.0300V
A0: 5.2480V A1: 0.0280V A2: 1.0240V A3: 0.0540V A4: 0.0080V A5: 0.0320V
Looks like A2, A3 show some kind of values.
I use Lipo 3s 1800mAh battery and power module from NAVIO2 kit.
Even current should be > 10A why there is no voltage.
In fact voltage is very crucial since it is very easy to drain your battery.
Other important question; can you setup some kind of security limit to cut of battery and protect it from damage? Standard ESC has such a feature. Does Navio2 power module has it?
I would appreciate your guidlines. I read this forum and no clear answer.
vcompl
(Martin)
June 12, 2017, 10:18am
7
EMLID - please response. Same issue with Batt voltage = 0 in Mission Planner. This data is quite crucial.
Please tell what else can be checked on AruPlane / Mission Planner config side?
Does above data prove that NAVIO2 kit power module is electronically ok and this is just data transfer issue?
vcompl
(Martin)
June 12, 2017, 4:18pm
8
Additionally, I’ve checked using MAVProxy:
1924: SYS_STATUS {onboard_control_sensors_present : 23198783, onboard_control_sensors_enabled : 6421567, onboard_control_sensors_health : 24181807, load : 15, voltage_battery : 0, current_battery : 0, battery_remaining : 100, drop_rate_comm : 0, errors_comm : 0, errors_count1 : 0, errors_count2 : 0, errors_count3 : 0, errors_count4 : 0}
Mavlink transfer 0 battery voltage.
As you see above I get voltage from python level and rcio level
1002
So what is wrong with arduplane setup? Why there is no voltage in mavlink data?
Can somebody answer? Or this is something else? Please give me some guidelines; I am getting really desperate
Sorry it’s taken me so long to reply. Could you please set BATT_VOL_PIN
to 2 and CURR_PIN
to 3 in your parameter list, reboot and then try power module configuration once again.
