Hi
I am new to Ardupilot Navio2( Linux based Ardupilot).
- Can someone let know if Navio2 can be used for fixed wing ? Have used Matek F405 with stable images from ardupilot but wanted to know if Navio2 can be used for Fixed wing or not , If yes then any limitations ?
- As I see Ardupilot docs say limitation due to memory (which I don’t see case here as sufficient memory is available)
- Is there PCB schematic available for Navio 2 board , wanted to make sure of sensor connections + PDB, Current measurements etc.
Thanks for all help .
Hi Raptor,
Welcome to the forum!
We haven’t tested anything specific with fixed wing, but here’s an interesting similar project our user shared: Successfully 60min maden flight with Navio+. 4G cellular communication. You can also check other projects on the forum.
We don’t have a PCB schematic to share; everything necessary is printed on the board. However, we have a pinout and STL/STEP models.
Hi Olesia Riman
Thanks for the information !!
I would like to try both fix wing/copter you mentioned in your reply.
Could you let know if Raspberry Pi here acts just as Companion processor (as I see RC handling on Rasp Pi) or the entire Ardupilot runs on Raspberry Pi ?
Is this " Emlid Raspberry Pi OS" opensource (If user wants to modify for additional camera etc) ?
I see that Navio2 has its own STM32 (correct me If I am wrong here), How does it communicate with Navio2 about various sensor data SPI/UART - am assuming Mav?
Thanks again for the help and promise this will be my last query ![:slightly_smiling_face: :slightly_smiling_face:](https://community.emlid.com/images/emoji/apple/slightly_smiling_face.png?v=12)
