Versions:
- Raspberry Pi 3 Model B Plus Rev 1.3.
- Image version: Linux navio 4.19.83-emlid-v7+
- ArduPilot version: 3.6.11
The problem:
I’m currently trying to run a simple dronekit script which connects to the navio2 and then exits. I’m running the script on the Pi itself via ssh. When I run the following command:
python connect.py --connect 127.0.0.1:14550
I receive the following error:
WARNING:dronekit:Link timeout, no heartbeat in last 5 seconds
ERROR:dronekit.mavlink:Exception in MAVLink input loop
Traceback (most recent call last):
File "/usr/local/lib/python2.7/dist-packages/dronekit/mavlink.py", line 211, in mavlink_thread_in
fn(self)
File "/usr/local/lib/python2.7/dist-packages/dronekit/__init__.py", line 1371, in listener
self._heartbeat_error)
APIException: No heartbeat in 30 seconds, aborting.
File "connect.py", line 21, in <module>
connectMyCopter()
File "connect.py", line 17, in connectMyCopter
vehicle = connect(connection_string, wait_ready=True)
File "/usr/local/lib/python2.7/dist-packages/dronekit/__init__.py", line 3166, in connect
vehicle.initialize(rate=rate, heartbeat_timeout=heartbeat_timeout)
File "/usr/local/lib/python2.7/dist-packages/dronekit/__init__.py", line 2275, in initialize
raise APIException('Timeout in initializing connection.')
dronekit.APIException: Timeout in initializing connection.
Steps taken:
I’ve attempted to reinstall mavlink and mavproxy. I’ve also checked if arducopter is running correctly which it seems to be when using sudo systemctl status arducopter
I’m not entirely sure where I’m going wrong, I’m assuming it’s something to do with my connection setup. Any help would be greatly appreciated.
