Thanks for the help with posting this stuff. Just to clarify, you aren’t using an on-battery Battery Management System and instead are just running the sense wires to a connector for when you’re charging?
I’m not using any Battery Management System (BMS), and I’m just soldering directly to the batteries. I do not think a BMS is needed, as long as you make sure you do not over discharge the batteries, use a balance charger and test the internal resistance from time to time with the charger if it has that function. For the soldering, I use a high temperature on the iron (380-390C), sand the ends first, and start by adding a small amount of solder on the battery first, then once it is cooled I solder the pre-tinned wire to this. The battery barely gets warm at all and I have not seen any reduction in capacity.
one questions regarding the E8278 usb modem router that you used.
Is it possible to power this modem directly from the raspberry pi 4 usb ports ??
If yes, is it possible somehow to prevent the raspberry from recognizing this modem as a device ??
Hi! Which Air frame type did you choose for your drone on MP ? I am not sure about choosing V-Tail or Quadrotor x Type of frame on Mission Planner. Thanks for your help.
