multi-operator M2m chip
Hi Bernardo,
Welcome to the community!
Reach RS2 supports 2G and 3G connections, so if the SIM Card supports these connections, it should be good. Additionally, for multi-operators’ SIM cards, you may need to restrict it to 1 provider.
If I understand correctly, you are from Brazil. There will be a plan to shutting down the 2G/3G connection. As an alternative, you can use a Bluetooth connection. In iPhone, you can turn on the Bluetooth setting and connect to Reach with the Bluetooth icon, as below:
In Android, you will need to tap on the profile icon in the bottom right corner really fast, about 10 times, to activate the toggle.
