Multi local Outputs - LoRa & NTRIP
I’ve been out running some surveys over the last few days & had a chance to try out the new feature to output two correction streams at once from the RS3 Base.
Seems to have worked very well - it made the workflow a lot easier for collecting GCP’s with the Rover (LoRa) and using the Drone (Local NTRIP) with both output streams enabled at the same time.
Thanks for adding the suggestion to the firmware :+1: :smiling_face_with_sunglasses:
Cool, but how do you collect points and fly at the same time? /s
Hi Nick,
That’s awesome to hear :smiling_face_with_sunglasses: We’re glad the dual correction output made your workflow smoother. Feedback like this helps us keep improving. If you ever have more suggestions, always feel free to share.
Happy surveying!
I’m superhuman :smile: (I wish!!)
Just saves forgetting to switch things on & off - usually when I’ve walked to the futhest GCP & discovered I’ve not switched the LoRa on. Now it’s simply a case of “set & forget”.
Me too! That makes sense!
do you know if this works with the reach rs2? I cant seem to get it to work
Hi Jason,
Welcome to the forum!
Yes, this feature works with Reach RS2 too. It was introduced in firmware version 33 Beta 1, so make sure your unit is on the latest version. If you need to update it, here’s our guide.
