i am planning a Quadcopter which i will use to do Aerial Shots and Scan Land, i would like it to have smooth Flying abylity but also to be able to do impressive moves in the air for good fotage.
Planning on a F450 Frame so i have space for the Gimbal, Storage and maybe LTE Module.
For the Motors i was reading for this Quad Size it should have low kv around 1000 whit high torq for stabil flight, however most motors i find have very high kv (+2400) or are looking very outdated and have no good information about specs.
What are known and trusted brands for Motors? is there a good Kit which include matching ESC? Most info i find is about FPV Drones, with small Props up to 5 inch… i was planning to use 7-10 inch props
I would like also to run on a 6s Lipo since i understand efficiency will benefit from it on certain motor types? also unshure if the added weight will be worth it.
Can you help me with my Problems? i was taking last 4 hours to find out but can find not much info for my special case
Thanks and have a nice day!
