Bug in survey: I’m missing “collection start” and “collection end” values in the csv export.
Hi @tobias-dahms,
May I ask you to share your csv files with missing values? Could you please also post Reach system report?
I only have the exported csv here. If it is necessary I can post the report later.
Hankhausen GPS DGM Test-CSV (1).zip (1.7 KB)
Might be connected to the fact that I used Reach in Single mode. Actually I was hoping to use the file (and the collection start and collection end information) afterwards to process the PPK data in Python.
Is there any possibility to use the survey future for PPK?
Looking forward to your system report! Now it’s hard to say what’s wrong.
I don’t think Single might influence.
If you mean “Stop-and-go” method, it isn’t implemented for Reach in the meantime. I wrote about it in this thread:
Simple system report
app version: 2.14.0-r0
'wifi_status, interface: wlan0':
- wifi_mode: wpa_supplicant
- ip: 192.168.xxx.xxx
is_connected: true
mac_address: xxx:f1:xx:xx:9e:bf
ssid: xxx
base mode:
base coordinates:
accumulation: '30'
antenna offset:
east: '0'
north: '0'
up: '1.045'
coordinates:
- '53.1xxxxxxxxxxx'
- '8.1xxxxxxxxxxxxxxxxxxxx'
- '47.114'
format: llh
mode: manual
output:
enabled: false
format: rtcm3
path: tcpsvr://:9000#rtcm3
type: tcpsvr
rtcm3 messages:
'1002':
enabled: true
frequency: '1'
'1006':
enabled: true
frequency: '0.5'
'1008':
enabled: true
frequency: '0.1'
'1010':
enabled: true
frequency: '1'
'1019':
enabled: true
frequency: '0.5'
'1020':
enabled: true
frequency: '0.5'
'1097':
enabled: true
frequency: '1'
'1107':
enabled: true
frequency: '0.5'
'1117':
enabled: false
frequency: '1'
'1127':
enabled: false
frequency: '1'
bluetooth:
discoverable: false
enabled: false
pin: '***'
camera:
duty cycle: 20
enable: false
period: 2
polarity: true
correction input:
input2:
enabled: false
format: rtcm3
path: ttyMFD2:57600:8:n:1:off
send position to base: 'off'
type: serial
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: false
version: null
correction:
format: RTCM3
started: false
version: null
interval: '24'
overwrite: true
raw:
format: UBX
started: true
version: null
solution:
format: ERB
started: false
version: null
position output:
output1:
enabled: true
format: erb
path: ttyMFD2:38400:8:n:1:off
type: serial
output2:
enabled: true
format: llh
path: :2013
type: tcpsvr
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh
path: :2015
type: tcpsvr
rtk settings:
elevation mask angle: '15'
glonass ar mode: 'on'
gps ar mode: fix-and-hold
max horizontal acceleration: '3'
max vertical acceleration: '2.5'
positioning mode: kinematic
positioning systems:
compass: false
galileo: false
glonass: true
gps: true
qzs: true
qzss: true
sbas: false
snr mask: '35'
update rate: '5'
Could this be an error fixed in 2.14? I’m not sure whether I did the survey before or after the update.
and @EarthImage Peter. ; )
Hi @tobias-dahms,
It might be possible that the survey project is old, and these values just weren’t generated. I recommend you to test it with the 2.14 version again. I tried to reproduce the issue, however, I didn’t succeed.
Please inform us about the test result!
Hi @tobias-dahms,
Did you try to collect points with the 2.14 version?
Yes, I did it and Reach too. So it might be connected to a earlier firmware.
That is good for future surveys, but is it possible to get the missing start and end time from somewhere inside the system?
Thank you very much,
Tobias
Hi @tobias-dahms,
As I said earlier, it seems time values just weren’t recorded. I’m afraid there are no ways to find it out.
