Is there a specific place to ask about the Dev versions?
I just updated from 15.3 to the Dev 2.15.4 and the antenna height input changed from 15.3 version. I also had the save survey point crash which has never happened.
Suggestion, if a person has the correction (65mm) enterred in software, then the Reachview app does not need to add it. You may want to make that optional (ie __ add 65mm to antenna height) If person checks box, it adds 65mm.
I was collecting a survey point and it crashed (ios). Never had that happen before. I also noticed you can not adjust the antenna height for a specific point. Never had the need to do it but that seems to no longer be an option.
