Using a Reach RS+
First, I get my iPhone and the reach on the same network. I then open ReachView 3 and my screen shows the image below:
This suggests that the Reach firmware is outdated or something isn’t set up so I follow the prompt and select “Set up Reach” and the following page appears:
This suggests that my ReachView version is up to date, but it doesn’t provide information about the Reach unit itself. For the moment I assume that everything is up to date. So, I restart everything and open ReachView 3. Again, I get the screen from the first photo suggesting that that something is outdated or not set up.
I select “Set up Reach” which takes me to the Updater. I then notice that I can select the TOC toggle in the upper righthand corner shown below:
Now I’m able to navigate ReachView (somewhat) as desired. However, I seem to still be operating within the “Updater” interface. Notice the Updater option in the photo below:
This isn’t a huge deal as I can still survey as I would like. However, it’s a bit cumbersome to have to navigate through Updater every time I connect to the Reach, and it blocks off part of the screen.
Any ideas what’s going on here?
