I have tried to import pointing into my Rover RS+ using reachview version 2.16.2 and I keep getting the same error message “At least one of the required columns is missing: Column “Elevation””. I have followed the template for .CSV, both importing the file and manually typing the text and I get the same message. Help - newbie here
Example of the text of a point I tried to enter: A,50.654933,-123.901667,686.00
FYI - the template shown on screen and the downloadable file example switch the order of the longitude and latitude columns. Does it matter which order the columns are in for importing?
Hello @johnson.tyler.k,
Im having a similar problem as you previously did, though the problem is on my iPhone, did you have to install an upate or anything to make it work?
Hello @tatiana.andreeva,
Ive attached a ZIP file of the CSV im using as this platform does not support CSV files, alternatively i have attached a screen shot of the data in the CSV if that helps
