by against
wifi works to connect to internet
by against
my last line is:
sudo APMrover2 -A udp: 192.168.1.2: 14550 -C / dev / ttyAMA0
giving the line: Raspberry Pi2 with BCM2709!
0
it gives you no clue my last sentence?
I say that the 3 methods e not work then,
why do you say that this is RFD900?
itâs been 4 years since I use everywhere without problem RFD900
I do not understand this reasoning
I repeat: I managed no communication between the Navio + and the PC with all the methods that exist
these are 2 new RFD900 I just bought
I tested with Pixhawk and they work fine
I do not want to destroy the new
Iâm afraid now
thank you
I give you precision:
Navio + on the RFD900 is connected UART with separate 5V supply
with excellent regulator
on my PC are connected in the RFD900 USB to COM port in FTDI
the same way that I use with Pixhawks
when I put the line
I get the line:
0
the LED of Navio + flash by regular intermittent orange per move 2
Ok do you see the telemetry on the PC when you use the udp to connect?
You also should power the rfd900 through the PWM connectors and a BEC added there instead so they all share the same GND.
RFD900 requires a separate power supply because it takes up to 3 amps.
I am connected to a controller better than a BEC. Much more accurate and stable.
No, I saw no télémétire because not communicate with the PC.
I just plug a new RPi2 and a new Navio +
Itâs time to see what happens
I wonder if it is possible to communicate between the PC and the USB + Navio?
Do you have a wifi or cable connected?
Is Ethernet setup of proper IP address or you might use DHCP to get up IP address.
Can you ping your PC (192.168.1.2)?
You said test #2 worked but now you said there is no connection to PC using udp?
I am getting confused.
Editing this because my response about the USB did not sound right:
better to refer to RPI community:
https://www.raspberrypi.org/forums/viewtopic.php?f=63&t=35341
everything is correct wifi side
I always say that it had never worked
right now, I try a new RPi2 and a new Navio +
I am trying to configure
Then Iâll see if the problem persists
thank you for wanting to help me
does it uploade the APM firmware?
mistranslation
I do not seek a RPi2 and Navio + nine.
I already have an RPi2 and Navio +
if you want to assist me
I believe that the problems come from
APMrover2
in momoent, I am not able to write the line:
sudo APMrover2 -C / dev / ttyAMA0
the Navio + new !!!
Can you do a screen shot of the command you type? There seems to be some extras space between â/â that should not be there.
Which language do you speak?
français
oui lâĂ©criture est correct
this writing work with each other but,
not therewith
I apologize but,
Iâm not in my normal state
I am at witâs end
I see clearer
and I start to dislike it
I should take a long break
are we could make an appointment for another day?
I really need help
I must have his head rested
my writing is correct
itâs the same with the other Navio +
I seem to have lost $ 600
for 2 X Navio+
and 2 X RPI2
