Hi Frank,
Welcome back to the forum!
If you were successful in obtaining the correct coordinates for the base, you have two options for continuing to work on the site:
Create a project in Emlid Flow in your state plane CS. You can find it the easiest way, if you enter its EPSG code: 2240. Import your points into it. Then go to the Base mode tab, hit the Configure button and add your base coordinates in NAD83.
Create a project in Emlid Flow in your state plane CS. Import your points into it. Then go to the Base mode tab and hit the Configure button, but this time choose the manual coordinates entry method and hit Choose from project. Then select the necessary point for the base. The app will transform the state plane coordinates into geographic ones. You can find more details about this method in our support tip.
If you’d like, you can try both options and check the results!
