pemase
(Peter)
June 21, 2019, 11:34pm
1
Hello, I have a Reach RS / RS + and I need to fly with a Phantom 4 Pro to make a map with GCPs and PPK. Could someone advise me how I should get each of the points? That is, for how long should I leave the unit collecting information and what parameters should I have in the Reach?
Thank you very much.
timd1971
(Timd1971)
June 22, 2019, 1:46am
2
There are tons of threads on all of this.
Recent thread:
Hi all! Could someone point me to a workflow on collecting GCP’s with the PPK method and extracting the points with RTKLIB? I am sure it has been covered before, but I haven’t exactly been able to find it. I of course would use RTK if possible, but very rarely is that reliable across whole projects with the RS+ receivers. I normally use another manufacturer’s gear and have CAD/site control, but we have several situations where there is nothing and I would like to learn how to do something like t…
Try youtube and Emlid Docs here also.
Hi @pemase ,
If the Fix solution is reached, 10 seconds for collecting a GCP would be enough.
You can follow this video guide to configure base and rover setup properly.
I also recommend you to examine this tutorial: Placing GCP in RTK mode .
system
(system)
Closed
October 18, 2019, 3:46pm
6
