Im thinking of buying the Emlid Reach RS3 with tilt compensation. Can someone tell me how the compensation (angle and heading) is stored in the export file.
When i export an csv file i have the fields Longitude, Latitude and Ellipsoid height. Are these the coordinates/height of the sensor or of the ground point (with the offset (Lengh of pole, angle and heading)
Or is the Lat/Long the sensor and the Offset is included in Easting and Northing?
May can someone share the first two lines of the csv?
Like these I have from Emlid Reach RX
Name,Code,Easting,Northing,Elevation,Description,Longitude,Latitude,Ellipsoidal height,Origin,Easting RMS,Northing RMS,Elevation RMS,Lateral RMS,Antenna height,Antenna height units,Solution status,Correction type,Averaging start,Averaging end,Samples,PDOP,GDOP,Base easting,Base northing,Base elevation,Base longitude,Base latitude,Base ellipsoidal height,Baseline,Mount point,CS name,GPS Satellites,GLONASS Satellites,Galileo Satellites,BeiDou Satellites,QZSS Satellites
1,,30000.321,200000.920,700.500,,15.76391740,49.41022325,802.732,Global,0.230,0.210,0.571,0.312,1.945,m,SINGLE,RTK,2025-02-09 14:54:52.8 UTC+01:00,2025-02-09 14:54:57.8 UTC+01:00,26,1.1,1.3,,,,,,,0.000,APOS_VRS32_GRID2021,MGI / Austria GK Central (2021) + GHA height,,,,,
Thx for helping
