I’m trying to have a working setup with a single Reach RTK configured as rover getting NTRIP corrections.
“So far so bad” never experienced a Fix neither a Float solution.
Reach stuck in Single and I’m suspecting there’s some incompatibility with the caster I’m getting corrections from.
Some picture of my setup:
is not similar, it’s the SAME.
Thank you @bide, I’ve searched across the forum but not noticed this thread.
I hope that someone from Emlid will start to analyse this issue
The corrections are not coming through for some reason. First, I would suggest to try RTCM2. Maybe this caster just works in another format. If this does not help, PM me with caster details, I’ll take a look.
Hi guys,
I’ve definitively found the source of my issue which is in the caster itself.
Today I’ve set up another one (for Italian guys, ItalPos from Leica) and quickly get a Float and then some sporadic Fixes.
My next big problem now is how to fine tune the satellite reception to get a stable Fix.
@egor.fedorov I think will be anyway useful to debug the log file I’ve sent to you to understand which type of mismatch Reach RTK has with that caster, don’t you think so?
