Having trouble keeping and getting a fix with rs2 and rs+
Hi Eddy,
Let’s start troubleshooting by following the hints and prompts in this Support tip. It contains the most important things to check in the receiver configuration.
If it doesn’t help, please share more details on this issue with us via support@emlid.com. The following information and logs would help a lot:
Just in case, have you tried swapping the antennas? Or run the receivers as a base and rover via Emlid Caster? It can help us pinpoint the issue’s root.
