I have a reach connected to my laptop by USB. Is it possible to get access to the raw GPS data this way? I would just like to have the data printed in a terminal in real time if possible.
I’m running ubuntu but I’ve never managed usb connections with the terminal, so any help is appreciated!
@egor.fedorov I tried that but I don’t know how to access the data on my laptop after setting up the connection. If anyone knows the procedure I would really like to know though
When connected over USB, Reach will automatically create a /dev/ttyXXX entry. You can open this port with something like screen /dev/ttyXXX baud_rate. The XXX name differs from time to time, usually it’s ttyACM0 or ttyUSB0.
Hi! I have a very similar problem, but I am using Windows. I’ve configured our Emild Reach to send data via USB-to-pc. The software of our thermal camera is supposed the accept GPS information (NMEA, RMC), but it (and either the laptop itself) does not recognize the emild Reach connected via USB. Could somebody please help?
See if Reach creates a COM port on your Windows machine. Try to read the COM ports on your PC with a terminal app, like RealTerm. If none of the COM ports contain NMEA output, install the flash tool for Windows(found here). It will also install special drivers, which will help.
