Hello everyone, I am a new Emlid user and recently purchased an RS2+ and RS3. I am using the RS2+ as a base and the RS3 as a rover. I have a couple of issues so far.
Getting my rover to show on the survey map. I followed the video tutorials and docs on how to set up the base and rover, but when I go into the survey tab in the Emlid Flow app, only my base shows up. When I connect to the rover wifi and go to the survey tab, it says that no receivers are connected.
Achieving a fix solution on my rover. I am based in Paraguay, so connecting to a nearby CORS station is not an option. Connecting to an NTRIP Caster is not always possible because the internet coverage is not stable across the country, so I won’t have cellphone signal most of the time in the field. My base is setup with an Average Single solution and I successfully connected my rover to the base so it is receiving corrections over LoRa, but still, I can’t get a fix solution or my rover to show up on the survey screen.
