Hello, I’m having trouble with an RS2 and not being able to enable Mobile Data (using ATT) in firmware version 2.22.7
I had the Dev firmware enabled and was having problems with connecting to the RS2 when not using wifi. I connected to the RS2 on wifi, disabled dev updates, and used the Reach Firmware Flash tool to flash the unit to 2.22.7.
After flashing, I could not get the mobile data to activate (it had worked an hour earlier on the dev firmware), and I read of others using ATT that had similar trouble at version 2.22.7.
I then re-flashed the unit to 2.22.5, but as soon as I restart the unit, it forces me to update to 2.22.7.
How can I flash the unit to an earlier firmware version and NOT update to 2.22.7? Is there some way to skip the updater portion of the setup after flashing the firmware?
Thanks,
- Ryan
