Hi, just getting Reach setup with Pixhawk - installing in an x8/octa-quad frame. I have not experimented with custom firmware for the Pixhawk, but I was expecting to find an octa-quad version of the copter 3.3.3-ERB firmware in the firmware download.
Will there be a separate release of X8 firmware, or is there a setting to change the frame type from flat octa to octa-quad in the ArduCopter-octa-v3.3.3-ERB.px4 version?
@Charlie_Robinson the package has been updated to include all vehicles. Please give it a try now and don’t forget to share the results of your test:) Remember to keep both antennas on big ground planes, not covered by obstacles and away from other electronics.
Thanks, all set up now, will take it out for a ground test later, but it all seems to be working. The setup instructions don’t mention disabling the wifi on the rover module, does that present an interference risk with the frsky link?
FrSky ACCST is really good at handling interference so that should not be a problem:)
We use it on our frames and never had a problem with RC\WiFi interference.
all up and running, tested on the ground, will get it out to the field for a test as soon as weather permits. Thanks very much, very straightforward…
Well, had a very brief window to get out today to fly. Unfortunately when I got down to the field the Reach that was configured as base station would not allow a connection - although my phone wifi hotspot showed the device as connected the LED stayed solid red and I can not connect to reachview. Don’t seem to be able to connect to the Reach in wifi setup mode either, led blinks green for a while then shows solid red again.
Are there any steps I should take before attempting to reflash the unit? Quite puzzling as I had the setup working perfectly less than 24 hours ago, and apart from moving to the flying field no change whatsoever to the configuration.
Ok successfully reflashed via cli, and setup and working correctly it seems. Any ideas for what might have happened to the unit would be great so I can avoid a repeat…
I’ve made my best guess about what was going on in your case and pushed an update v0.3.1. It should minimize the chances of the same error happening again to practically zero.
