@polina.buriak Today I had very few satellites at the base, only 16 and in rover 25.
The base was in a clear place. Cula would be the reason for this failure
SystemReport.zip (863.4 KB)
solution_201911281138_LLH.zip (242.0 KB)
Your ubx, is that from the base or rover ?
At the 13:32-mark, you suddenly loose all Gallieo-sats. Did you change a setting?
Also, why are you not also logging Beidou?
Hi Christian, it’s the base file. Yes, I took and put satellites to see if I modified the reception.
Beidou not use, only gps glonass and galileo
Did you have clear sky-view all the way around?
Why are you not using them ?
at 13:32 Utc do not modify anything ! in the view of satellites of the Galilean base it stopped receiving. I’m going to see the Rover
I’m in South America, but the Rover has 25 satellites and only 16 the base
ROVER
It was worked at 1 Hz on both receivers, modify the Rover to 5 Hz and the satellites were 32 on the base and 36 on the Rover. but then I went to 1 Hz again and it worked without problems. there is something in version 2.21.2 that is not working well. Christian add Beidou!!!
I have seen this before:
Hi Tobías! My problem is in RS2
Hi Luis,
or probably in ReachView?
I think the same
Hi Luis,
May I ask you to share a Simple Report from the rover as well?
Well there I share it!
app version: 2.21.2-dev-r0
'wifi_status, interface: wlan0':
- wifi_mode: ap
- access_point:
band: bg
channel: 1
password: null
ip: 192.168.42.1
is_added: true
is_connected: true
mac_address: 6C:21:A2:93:31:48
security: wpa-psk
ssid: ROVER-02:FD:7F
uuid: cbe9b68a-4039-4b73-a51d-7e04d7c4a75a
base mode:
base coordinates:
accumulation: 2
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- 0
- 0
- 0
format: llh
mode: single-and-hold
output:
enabled: false
format: rtcm3
path: tcpsvr://:9000#rtcm3
type: tcpsvr
rtcm3 messages:
'1006':
enabled: true
frequency: 0.10000000000000001
'1074':
enabled: true
frequency: 1
'1084':
enabled: true
frequency: 1
'1094':
enabled: true
frequency: 1
'1124':
enabled: true
frequency: 1
bluetooth:
discoverable: true
enabled: true
pin: '***'
constraints:
lora:
frequency:
- - 902000
- 928000
correction input:
input2:
enabled: true
format: rtcm3
path: '***:***@ny.youcors.com:2101/MC001'
send position to base: 'off'
type: ntripcli
input3:
enabled: false
format: RTCM3
io_type: tcpsvr
path: :9028
device: null
logging:
base:
format: RTCM3
started: true
correction:
format: null
started: null
debug: false
interval: 24
overwrite: true
raw:
format: UBX
started: true
solution:
format: LLH
started: true
lora:
air rate: 9.1099999999999994
frequency: 902000
mode: read
output power: 20
position output:
output1:
enabled: true
format: nmea
path: bluetooth
type: bluetooth
output2:
enabled: true
format: llh
path: :9001
type: tcpsvr
rtk settings:
elevation mask angle: 15
glonass ar mode: 'off'
gps ar mode: fix-and-hold
max horizontal acceleration: 1
max vertical acceleration: 1
positioning mode: kinematic
positioning systems:
compass: true
galileo: true
glonass: true
gps: true
qzss: false
snr mask: 35
update rate: 5
sound: null
Hi Luis,
Thanks for sharing the report!
I’ll try to reproduce this issue as at the moment it’s difficult to understand what causes the issue.
Hi Luis,
I couldn’t reproduce this issue in the office.
May I ask you to recall precisely if at 13:32 UTC you modified the RTK settings and the correction output?
Also, according to the simple report you sent, your rover receives corrections from the NTRIP service, not from the base via LoRa. Would you mind clarifying the way you received corrections from the base?
Hi Polina! Do not change any settings, the correction is by NTRIP.
