Hi all,
once I calibrate the compass I can not start the ardupilot service, I tried 2 different navio2 on 2 different RPi3.
I get this message:
pi@navio:~ $ sudo systemctl status ardupilot.service
● ardupilot.service - ArduPilot for Linux
Loaded: loaded (/lib/systemd/system/ardupilot.service; disabled)
Active: failed (Result: start-limit) since Thu 2017-01-19 10:48:56 UTC; 2min 8s ago
Process: 1070 ExecStart=/opt/ardupilot/navio2/arduplane/bin/arduplane $ARDUPILOT_OPTS (code=exited, status=1/FAILURE)
Main PID: 1070 (code=exited, status=1/FAILURE)
Jan 19 10:48:56 navio systemd[1]: Unit ardupilot.service entered failed state.
Jan 19 10:48:56 navio systemd[1]: ardupilot.service holdoff time over, scheduling restart.
Jan 19 10:48:56 navio systemd[1]: Stopping ArduPilot for Linux...
Jan 19 10:48:56 navio systemd[1]: Starting ArduPilot for Linux...
Jan 19 10:48:56 navio systemd[1]: ardupilot.service start request repeated too quickly, refusing to start.
Jan 19 10:48:56 navio systemd[1]: Failed to start ArduPilot for Linux.
Could you please post the output of sudo journalctl -u ardupilot
and uname -a
pi@navio:~ $ sudo journalctl -u ardupilot
-- Logs begin at Thu 2017-01-19 10:28:10 UTC, end at Thu 2017-01-19 10:31:55 UTC. --
pi@navio:~ $ uname -a
Linux navio 4.4.48-v7+ #964 SMP Mon Feb 13 16:57:51 GMT 2017 armv7l GNU/Linux
I guess you ran sudo apt-get upgrade
on the latest Beta, right?
Unfortunately you stumbled upon the bug other guys described over here. The fix will also be there.
This command can help you figure out why it didn’t get launched. But you need to try first. That’s why there’s nothing of interest there.
-- Logs begin at Thu 2017-01-19 10:28:10 UTC, end at Thu 2017-01-19 10:50:14 UTC. --
Jan 19 10:38:46 navio systemd[1]: [/lib/systemd/system/ardupilot.service:4] Unknown lvalue 'Documentaion' in section 'Unit'
Jan 19 10:38:46 navio systemd[1]: Starting ArduPilot for Linux...
Jan 19 10:38:46 navio systemd[1]: Started ArduPilot for Linux.
Jan 19 10:38:46 navio arduplane[828]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
Jan 19 10:38:46 navio arduplane[828]: Raspberry Pi 2/3 with BCM2709!
Jan 19 10:38:46 navio systemd[1]: ardupilot.service: main process exited, code=exited, status=1/FAILURE
Jan 19 10:38:46 navio systemd[1]: Unit ardupilot.service entered failed state.
Jan 19 10:38:46 navio systemd[1]: ardupilot.service holdoff time over, scheduling restart.
Jan 19 10:38:46 navio systemd[1]: Stopping ArduPilot for Linux...
Jan 19 10:38:46 navio arduplane[839]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
Jan 19 10:38:46 navio arduplane[839]: Raspberry Pi 2/3 with BCM2709!
Jan 19 10:38:46 navio arduplane[846]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
Jan 19 10:38:46 navio arduplane[846]: Raspberry Pi 2/3 with BCM2709!
Jan 19 10:38:47 navio systemd[1]: Stopping ArduPilot for Linux...
Jan 19 10:38:47 navio systemd[1]: Starting ArduPilot for Linux...
Jan 19 10:38:47 navio systemd[1]: Started ArduPilot for Linux.
Jan 19 10:38:47 navio arduplane[854]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
Jan 19 10:38:47 navio arduplane[854]: Raspberry Pi 2/3 with BCM2709!
Jan 19 10:38:47 navio systemd[1]: ardupilot.service: main process exited, code=exited, status=1/FAILURE
Jan 19 10:38:47 navio systemd[1]: Unit ardupilot.service entered failed state.
Jan 19 10:38:47 navio systemd[1]: ardupilot.service holdoff time over, scheduling restart.
Jan 19 10:38:47 navio arduplane[861]: LinuxPWM_Sysfs:Unable to open file /sys/class/pwm/pwmchip0/pwm0/duty_cycle: No such file or directory
Jan 19 10:38:47 navio arduplane[861]: Raspberry Pi 2/3 with BCM2709!
Yep, this is what I suspected. Head over the thread I linked above. I’ll close this one if that’s okay.
