Is anyone aware of a commercially available power/data cable for connecting an RS2 or RS3 to a Trimble TDL450H external radio? From what I can see, it appears that Harxon external radio have an identical pinout to the Trimble external radio.
May not need it but wanted to point that out as the DB9 cables are DATA ONLY (so no surprise) in case u need power also for whatever else u may be doing.
Appreciate it thankyou, yes I am wanting it to be semi permanent so definitely need power. It’s certainly proving to be a good thing Emlid incorporating a UHF 450 radio into the receivers, just be handy if it could work with CMRx or even CMR+ so we don’t upset all the Trimble guys making them change their settings when going to an all Trimble site
Yes, timd1971 is right. If you want power for a permanent base you will need the unterminated cable and install your own DB9 which only needs Tx, Rx & SigGnd as per diagrams. The pinouts are fine.
That said note UHF is generally not used on a permanent base (at least here in Aus & surveying), ACMA Area Wide Licences that enable you to go to sites have transmission duration conditions.
