I’m hearing you, it’s just a shame you can’t power them through the Lemo -DB9. It is starting to look like the easiest option though
You can, just get the unterminated cable and install your own DB9. It’s only 3 wires and takes minutes.
And if you aren’t handy with fine soldering and worried about botching it up, and can’t find anyone to help do it, then these are klutz-proof: 1-6x DB9 Male/Female 9Pin to Screw Terminal Connector Signal Module AU Stock | eBay
Hi Brenton, yes, we have this cable customized. If you want to connect your radio with the Reach, you can use our 9-pin without end and customize the other ends
Hi Yamete, we don’t sell the cable separately and it comes as a part with the Harxon Radio
Tolong di jual secara terpisah
Hi @Riyanlog,
I’ve added your request to sell the customizable cable with the Harxon Radio as a separate item. I’ll update you when I have more information. However, I can’t provide an estimated timeline since there are no plans yet.
Additionally, since this is an English language forum, please keep all communication in English so that other users can also engage. Thank you!
