When creating a Project in Emlid Flow w/ Survey, I always set the Linear Units to Feet. Does that setting affect the units for the Base rod height or is the Base rod height always entered in meters?
Hi Steve,
No, it doesn’t affect the base settings in general. However, setting the antenna height in the Base settings is always available either in feet or meters on your choice. You can switch between them using this option:
Overall, to set the Base position when you know its coordinates in local projection and units, you can follow these steps and configure it using the point from the project.
