Hello everyone,
I built a basic quadcopter which is like Igor’s (Navio+, RPi2 with APM 3.3, Q450, 4-in-1 20A ESC, Multistar 2212-920). I also added Airborne’s 3D printed case.
Everything worked fine last summer. Then I tried to protect the barometer from UVs with a foam, and finally removed the foam since the 3D printed case should suffice.
Today my problem is: the drone takes off, flies fine for ~30 sec in Loiter mode at 3 meters altitude, then the engines progressively lose power and the quadcopter lands quite harshly despite full throttle. I tried to take off again with different flight modes, but the quadcopter lacked power to succeed.
Do you have any idea why the drone can’t fly more than a minute ?
I have 3 different batteries which look fine.
Thank you,
Best regards
