mlebret
(Marc Lebret)
August 26, 2017, 4:44pm
1
Navio2 ROS (latest), Arducopter 3.5.2
Logging is not working well…
It could be no log, or log lenght = 0, or FMT MSG missing from log, or a good Log.
Latest try, DataFlash log erased,
BackEnd type = 1
Bitmask = 830
BufSize = 16
Small Try at home, log is OK
Small fly (4mn), FMT is missing from log…
Logging was OK with 3.4.6 but erratic since using 3.5.x
7mn flight and empty log:
Thanks for your help.
Marc
Okay, this is a tricky one. Did you get any “SD card faulty” messages during the flight?
I’m also interested in SD card class you’ve been using. ArduPilot has set a little higher constraints on DataFlash logging speed in the latest release which might in fact yield these kind of errors. We’ll be looking into this problem. Thank you for confirmation.
mlebret
(Marc Lebret)
September 2, 2017, 3:27pm
4
george.staroselskiy:
SD card class
Hello,
It is a Verbatim 8GB class 10 card. I will backup and restore it on a 16GB Sandisk Ultra class 10.
Keep you in touch,
Marc
mlebret
(Marc Lebret)
September 3, 2017, 8:09am
5
FeedBack:
With SanDisk card, first log is OK then I have BadLogging msg and no registered log.
Marc
mwfoshee
(Mike Foshee)
September 12, 2017, 4:05pm
6
Same problem,
The logs file I have yields the same error,
Also, I’m not gererating logs files, I started and tested my unit a dozen or more times, yet only one log file was created.
Thanks.
mlebret
(Marc Lebret)
September 12, 2017, 4:38pm
7
May be a solution, I have to try it:
There is an option to close the log when disarming. More secure than closing by unplugging battery.
I activated it, but I have to fly (to much rain)
Marc
mwfoshee
(Mike Foshee)
September 12, 2017, 5:39pm
8
If I might ask @mlebret , what other settings are you choosing, file, mavlink, file+ mavlink?
also, here is my SD card (sorry about the blur pic)
mlebret
(Marc Lebret)
September 14, 2017, 12:44pm
9
Hello,
Sorry for the delay, I was moving my Navio2 from Hexa Gopro frame to a large Octocopter (QuadX) with Sony QX1.
Setting is file only.
Closing and saving log when disarming produced a valid file. I will fly later and feed back.
Marc
mwfoshee
(Mike Foshee)
September 15, 2017, 12:51pm
10
Thanks @mlebret , I found that deleting all the old logs corrected not generating a log file error, Kinda, Navio2 is generating log files, mission planner is still barking bad logging yet when I try to view the files I get an error no FMT messages in you log
mlebret
(Marc Lebret)
September 18, 2017, 9:49am
11
Hello,
I have no more problems with Log since I changed to “close log when disarming”.
Marc
mwfoshee
(Mike Foshee)
September 18, 2017, 10:01am
12
Thanks for reporting. Where is that option?
mlebret
(Marc Lebret)
September 18, 2017, 10:51am
13
mwfoshee:
Mission Planner:
Full parameter tree, Log entry.
Set LOG_FILE_DSRMROT to 1
Marc
mwfoshee
(Mike Foshee)
September 18, 2017, 3:23pm
14
mlebret:
anyone know why I wouldn’t have this option?
mlebret
(Marc Lebret)
September 18, 2017, 5:53pm
19
Maybe with Mission planner update? I have version 1.3.49.1
I use Arducopter 3.5.2 (update from Emlid available)
Marc
mwfoshee
(Mike Foshee)
September 21, 2017, 7:10pm
20
@mlebret is the update available using the “update -upgrade” process?"
Thanks
mlebret
(Marc Lebret)
September 22, 2017, 6:01am
21
mwfoshee
(Mike Foshee)
September 22, 2017, 9:48pm
22
OK, I updated successfully
Thanks @george.staroselskiy and @mlebret for the help.
I am now at Arducopter V3.5 and Mission Planner V1.49.4 and successfully enabled “Stop logging to current file on disarm”
I’m still not logging and now apparently because of one or both of the updates, not logging causes the HEX to fail pre arm checks. Now I can’t even arm the copter, or even worse, fly the copter. BRICK!
Any Ideas???
mlebret
(Marc Lebret)
September 23, 2017, 5:48am
23
Sorry for your logging problem.
You can uncheck “logging available” in mission planner Standard Params.
Marc
mwfoshee
(Mike Foshee)
September 25, 2017, 2:23pm
24
What makes this “Tricky” and what steps would you suggest to fix this. Thanks!
mlebret
(Marc Lebret)
September 29, 2017, 1:39pm
25
Hello,
Maybe a bit of solution:
Now, I managed to have logging OK by closing the log when disarming. Until last flight, the log is on the card but mission planner download an empty file…
So, I dig Linux doc, and search the forum to access Log directory on Navio card /var/APM/Logs
pi@navio:/var/APM/logs $ ls -l
total 19804
-rw-r–r-- 1 root root 2490368 Sep 21 12:51 00000008.BIN
-rw-r–r-- 1 root root 581632 Sep 21 12:53 00000009.BIN
-rw-r–r-- 1 root root 737280 Sep 21 12:54 00000010.BIN
-rw-r–r-- 1 root root 520192 Sep 21 12:56 00000011.BIN
-rw-r–r-- 1 root root 811008 Sep 21 12:58 00000012.BIN
-rw-r–r-- 1 root root 1753088 Sep 25 14:07 00000013.BIN
-rw-r–r-- 1 root root 321429 Apr 1 15:27 1.BIN
-rw-r–r-- 1 root root 103748 Apr 2 12:38 2.BIN
-rw-r–r-- 1 root root 1775897 Apr 5 12:26 3.BIN
-rw-r–r-- 1 root root 784163 Apr 8 13:26 4.BIN
-rw-r–r-- 1 root root 3379056 Apr 9 09:08 5.BIN
-rw-r–r-- 1 root root 4729122 Jan 12 1980 6.BIN
-rw-r–r-- 1 root root 2254040 Jun 1 15:34 7.BIN
-rw-r–r-- 1 root root 4 Sep 25 14:04 LASTLOG.TXT
A bit of sftp (transmit) on my mac and i got the log from the card.
Now Mission Planner “Review a Log” can read the imported log.
So where is the problem with Download DataFlash Log via Mavlink?
Dropbox Log import: https://www.dropbox.com/sh/94gae9b4cjgfry7/AACpDVPqFfAUSRJuxNpBDvXFa?dl=0
The relevant files are dated sep 21 to 25. (Octocopter).
Files dated sep 21 are fine with Download DataFlash
EDIT: Today download of log number 13 was fine… ?? Don’t ask ??
Marc
