Hi @Endure1,
If you add the base coordinates directly to Emlid Studio, the results will be in the coordinate system of the base. If you set your base in ITRF2014, you get the coordinates in ITRF2014.
I ultimately want to convert to UTMXXN.
You can upload the results to Emlid Flow to apply UTM. For instance, if you need a UTM projection based on NAD83(2011), you’ll need to use the NAD83(2011) coordinates of the base in Emlid Studio. You can check our Support tip for more detail.
Are there any plans to let the user choose the surveyed points CS output in Emlid Studio without having to import/export from Emlid Flow?
Currently, it’s not in our roadmap but it’s a valuable suggestion. I’ll note it!
