Connection to Caster issues
I noticed there is now an issue with getting NTRIP to start and talk between my base and rover with this beta firmware. Previously I could start the base, and go out and set targets, etc. while I wait for the base to launch. Then typically once it has launched my rover is already on and waiting and it gains fix. Twice now I have had to do a full reboot of my rover after the base launches to begin receiving corrections.
Hi @dbuchanan,
Thanks for reporting!
Is it possible that there is some issue with the Internet connection? Maybe, the connection is intermitted, and the rover can’t receive the stream of corrections.
Does this behavior change if you roll back to the stable version? It’s important to understand if it works differently in the same conditions and with the same settings.
I am going to roll it back today and let you know.
Just to follow up, rolled back to the previous firmware and there are zero issues.
I just want to say I think my hardware is now having this same issue with the latest 29 firmware. I only this morning upgraded from the 28.4 firmware I was on when I last had this problem. Either that or the Emlid Caster service is down.
@liudmila.slepova Can I send you the logs from my Base?
I cant get past the Reach setup to get back to my old firmware which worked. Its forcing it to go to the latest firmware which did not work for me. Please help, as I need these functioning to complete a few jobs.
In order to get it to work, here are the steps I had to do.
NTRIP via Hotspot alone DID NOT WORK.
To get NTRIP to work, I had to connect using Bluetooth (NTRIP over Bluetooth then became available).
Once connected to bluetooth, it would disconnect almost immediately.
The only fix I found to keep it from disconnecting, was to:
  1. Leave my hotspot on (even though I was connected via Bluetooth)
  2. As soon as the receiver connects via Bluetooth, tap on settings
It seems like for this unit, once I tap on settings, it stops disconnecting it from Bluetooth. I have no idea why this is, and I never had to jump through this many hoops when it was 28.4 firmware. For now, I will have to leave it alone because I need them for work!
LMK if you would like me to send logs, and maybe figure out why this is happening?
I have experienced similar results with my RS2
Hi @dbuchanan,
Am I getting it right that you’re connecting to our Caster? Do those disconnections happen only with the base receiver?
Via lora no it does not happen. But lora will not work on urban environments here in the states hence why I need ntrip. I think it’s twofold. I even swapped the base and rover units (base is now rover, and rover is now base) and it’s not just a one unit issue.
There seems to be issues with NTRIP and Bluetooth maintaining connection. When I return I will send logs.
Just to follow up, it looks like at least the bluetooth connectivity is related to Android OS 13. We tried the bluetooth connection and hotspot via iPhone iOS and it worked without issue. No idea what could have changed between Firmware that prevents Android OS 13 from working with it okay now.
Hi @dbuchanan,
Thanks for the details!
So the NTRIP over Bluetooth option works with your iPhone but not with Android OS version 13?
Correct! Android OS 13 broke a lot of things on this particular phone (Oneplus 8 Pro) so I am not surprised to see that its related to that and not the firmware.
I am once again having issues connecting my base to Ntrip.
I am on the latest firmware, with the base set up to send corrections out via NTRIP.
  • The base is an Emlid RS2+
  • I am connected to LTE via a T-Mobile sim card (I can see full bars in Emlid Flow)
  • It shows that there is data being sent under the data area in settings
  • I cant connect the base to Emlid Caster, it never says online.
  • I have tried with both an iphone, and an android phone, and it doesnt seem to make a difference
I am at a loss for what to do. I cant get my work done without this base working. Please help!
Hi @dbuchanan,
If the Reach device has internet access but shows offline on the Caster page, could you please check if your mount point is here? Also, please don’t forget to provide the Reach device with a sky view.
It had both of those things yesterday and did not show up. I am trying it again today, and now it doesn’t show there is mobile data/0 bars.
I have since restarted the device and it has 0 bars and still no connection to the caster. What do I do now?
Hi @dbuchanan,
Please share the Full System Report for your device. Since it contains sensitive information, you can email us at support@emlid.com.
Also, when you test it again, could you please check if the mount point you are using is here? Thanks!
Email sent
I want to update everyone that we are in contact with @dbuchanan via email. I’ll post the summary here as soon as we resolve the issue. Thanks!
